  1. toustok35
    By:toustok352 Juin 2015
    About Clay Eraser Mitt, Fine
    Chemical Guys Clay Eraser Mitt is the next-generation auto clay bar system. The Clay Eraser uses synthetic clay material to remove rough contamination from the surface of any vehicle. The textured Hex-Logic Geo-Impressions increase surface area of the Clay Eraser and quadruple the decontamination effect of each swipe. Use Clay Eraser to remove embedded contaminants, pollution, brake dust, industrial fallout, and overspray for a smooth-as-glass feel on your car, truck, motorcycle, or RV. Clay Eraser works on paintwork, headlights, windows, wheels, exhaust systems, and painted plastic surfaces all around your vehicle. The unique foam mitt wraps Clay Eraser around your hand as you work, conforming to all contours of your vehicle for perfect removal of contaminants, every time. Clay bar decontamination is a critical step for next-level detailing, and Clay Eraser cuts surface prep time by more than half.
    Hex-Logic Geo Impressions
    Utilizing Hex-Logic Geo-Impressions, Chemical Guys developed a Clay Mitt that delivers superior efficiency and speed combined with the most innovative design. Hex-Logic Geo-Impressions enables the user to cover larger surface areas faster, easier, safer and more efficiently than ever. Hex-Logic Geo-Impressions increase surface area of the Clay Eraser and quadruple the decontamination effect of each swipe. The Hex-Logic elastic hexagon shapes help lift tiny micro-particles and contaminants away from the surface. The Hex-logic shape encloses the largest possible area while wasting no space in between them. Therefore the Clay Eraser Mitt is able to capture tiny particles and contaminants in the surface area that a traditional flat surface would have not. The concept of Hex-Logic derived from the engineering involved with our Hex-Logic pads. Similar to the benefits that Bees have known when creating honeycombs in a hexagon shape, the Hex-Logic Geo Impressions in the Clay Eraser Mitt confirm that not only does the hexagon shape enclose the largest possible area, but the hexagon structure also provides a strong design to tackle the smallest or even the largest contaminants on any surface.
    [​IMG][​IMG]
    Easy To Use
    Using Clay Eraser is easy. Simply apply a generous amount of Chemical Guys Luber to a clean surface, gently glide Clay Eraser back and forth over paint, glass, wheels, and headlights. Wipe away the residue with a microfiber towel for a perfectly clean vehicle. Thin Foam Technology™ on the Clay Eraser mitt increases touch and sensitivity as you decontaminate the surface, gliding quieter and quieter as the surface becomes clean. Exclusive Hex-Logic Geo-Impressions increase the surface area off the mitt, and the grip on surface contamination. Each swipe with the Clay Eraser is equivalent to multiple swipes with a traditional clay bar. Simply rub until you can’t hear the mitt anymore—it’s that simple. Decontaminating any car, truck, motorcycle, or RV can take just a few minutes, and feel smooth-as-glass with Chemical Guys Clay Eraser.
    We developed the revolutionary Clay Eraser to be fast and easy-to-use. Traditional detailing clay can be difficult to handle, hard to keep clean, and must be thrown away when dropped. Clay Eraser is made with advanced plasticized material, and can quickly be cleaned with warm water if dropped on the ground. Clay Eraser uses multiple grades of clay to quickly cleanse embedded contaminants from the surface. Contaminants like overspray, road tar, brake dust, and industrial fallout can make your paint to feel rough, appear dull, and oxidize over time. Clay Eraser cleanses and restores your vehicle’s finish to a smooth-as-glass feel and unlocks its natural lustrous shine.
    [​IMG] [​IMG]
    Different Cars Need Different Attention
    Chemical Guys Medium Clay Eraser is designed for vehicles with moderate contamination. The Medium Clay Eraser removes embedded contaminants, pollution, road grime, and overspray from well-used and vehicles that sit outside without a garage. Clay Eraser is the perfect paintwork cleansing tool to decontaminate your paint before polishing, or applying your favorite wax or sealant. Claying your vehicle has never been this quick and easy.
    Chemical Guys Clay Eraser utilizes multiple grades of rubberized synthetic detailing clay to cleanse paintwork for perfect results on any vehicle with any level of contamination. Use Super Fine Clay Eraser on new cars with very light contamination. Use Fine Clay Eraser on cars with light contamination. Use Heavy Clay Eraser on cars that have never been clayed and have heavy contamination built up on the paint.
    [​IMG] [​IMG]
    Durable And Long Lasting
    Traditional automotive clay bars come in 100 gram blocks, and each block can decontaminate approximately 10 full sized cars. The new Chemical Guys Clay Eraser Mitt is designed to last and fully-decontaminate up to 50 full sized cars. Traditional detailing clay must be thrown away if dropped on the ground, while the Clay Eraser can simply be rinsed clean and wiped off. This makes the Clay Eraser more economical and practical than traditional clay bars.
    Easy To Maintain
    Traditional detailing clay has limitations: the mere act of dropping traditional detailing clay embeds it full of grains of abrasive dirt that scratch paint when rubbed across the car. If dropped on the ground, simply rinse Clay Eraser with warm water and wipe with a clean microfiber towel to remove any dirt or debris. Once cleaned, Clay Eraser is ready for action. Chemical Guys Clay Eraser was designed to be the easiest way to decontaminate any surface on your vehicle. It’s so easy to use that anyone can decontaminate a car, truck, motorcycle, or RV in a matter of minutes. Chemical Guys Clay Eraser is truly is the easiest way to clay your vehicle.
    Ultimate Versatility
    The Chemical Guys Clay Eraser decontamination system is the most versatile synthetic clay bar technology on the market. Use the ergonomic low-profile Clay Eraser mitt for tight spaces such as wheels and bumpers and large contoured body panels alike. For heavily contaminated areas, or exceptionally large vehicles, use the Clay Eraser Disc on your favorite dual action polisher. The gentle decontaminating action of the Clay Eraser combined with the power of the machine makes short work of any level of contamination on any vehicle. To tackle large vehicles without a dual action polishing machine, simply attach the Clay Eraser Disc to the Clay Eraser Disc Hand Pad to quickly clean any vehicle.
    Tarif :
    Retail Price $49.99
    Today's Discounted Price $39.99
    http://www.chemicalguys.com/Product...ocial&utm_medium=YouTube&utm_campaign=CLY_502
  2. gadjoe28
    By:gadjoe282 Juin 2015
    Merci pour la fiche :super:
    Il faut que j'essaie ce genre de clay,
    Pour gagner du temps en prépa.
  3. al27
    By:al272 Juin 2015
    Merci pour la fiche , mis a part qu'en francais elle aurai été mieux ::/: , sur smartphone pas évident de faire la traduction .
    Tu l'as testé ? Ton ressenti alors.
  4. toustok35
    Non je ne l'ai pas testé, c'est une nouveauté alors pour référencer le plus de produits/accessoires possible sur le forum je fait des fiches ;)
  5. pac226
    By:pac2262 Juin 2015
    11 Avril 2013
    Alfa Romeo 159 SW Ti
    Pierre-Alain
    Plus qu'à attendre le retour d'un early user :)
    Merci pour la fiche ^^
