Carpro Carpro IronX
Discussion dans 'Décontaminant, Clay, QD, Nettoyant jantes' créé par Béhième, 18 Février 2012.
    By:Béhième18 Février 2012
    Super Modérateur
    Marque :
    Carpro
    Produit :
    IronX
    Catégorie :
    Décontaminant jantes
    Photo :
    Description du fabricant :
    Highly effective, acid-free and pH balanced (6~7pH) car paint, wheels & glass cleaner (safe for all wheels including aluminum/Chromes/Anodized and alloys). This formulation is also effective and safe for use on all car surfaces and will not deteriorate clear coats. This preventative measure puts a stop to corrosion , IronX contains unique chemical ingredients that effectively dissolves the sintered iron by forming a water soluble iron complex. No other method cleans paint and wheels as deeply as IronX. The IronX Paint and wheels Decontamination System was developed as a method of removing paint contamination beyond what can be removed by washing or claying !!. If you are familiar with detail clay, you know it is capable of removing above surface contaminants that have bonded to the paint. The IronX is designed to remove what lies below the paint surface.
    Airborne chemical compounds and ferrous particles - particles containing iron - actually penetrate the paint and create corrosive compounds that eat deep into the paint's sub-layers or paint’s pin-holes. This is a gradual process that often is not evident until it's too late. Claying or polishing only removes the particle, not its effects, which are continuing to spread beneath the surface.
    During the use of your vehicle, brake dust and road grime become sintered to the surface of the car paint , rims and wheels due to the high temperature conditions they are normally exposed. Brake dust contains high levels of iron and once sintered to the rim, becomes extremely difficult to dissolve or remove without the use of harsh chemicals. IronX opens up the paint's pores to release ferrous particles and to neutralize caustic compounds that have developed in the paint's subsurface. Ongoing damage is immediately stopped and future damage is prevented by removing the ferrous particles.
    IronX sprays on as a thick, transparent, as the cleansing liquid begins to work into the dirt and grime, the formula begins to turn purple/ red. The purple/red coloration is the IronX Cleaner forming a bond to the sintered iron on the car paint and wheel and changing its state to a water soluble complex for easy removal. Stubborn, baked on grime may take a small amount of agitation. Rinse car paint and wheels thoroughly with a power washer and wipe dry.
    The IronX is used by body shops for pre-cleaning prior to detailing and by dealerships for new and used car prep. It is proven to deliver a clean, glassy smooth vehicle that is protected from the harmful effects of paint contamination. No other is as fast and effective at removing multi-layer paint and wheels contamination.
    Description du produit :
    IronX est un nettoyant multi-surface de PH équilibré (6/7), sans acide, particulièrement efficace sur tous les éléments peints de votre véhicule, ainsi que les jantes (même en aluminium ou alliage particulier).
    Les contaminants chimiques et les particules ferreuses s'insinuent dans la peintures et créent des composés corrosifs qui, à terme, altèrent la surface de votre véhicule.
    Ce phénomène est d'autant plus dangereux, puisqu'il est progressif : quand on s'aperçoit du ternissement, il est trop tard...
    Seul un traitement curatif, le polissage, va permettre de traiter les effets ces corrosifs sur la surface de la carrosserie. Mais rien n'indique que le phénomène ne se répande ou ne s'aggrave pas sous la surface.
    IronX ouvre les pores de la peinture, libère les particules ferreuses et neutralise les composés caustiques qui se sont développés. Les dommages en cours sont immédiatement stoppés et ne se propageront plus, puisque les particules ferreuses auront été éliminées.
    IronX est à la base un liquide translucide qui va travailler au cœur des saletés et de la crasse.
    Sa formule commence à tourner au violet/rouge quand son action prend effet !
    Sur les jantes le changement de couleur au pourpre/rouge montre l'action du IronX sur les particules ferreuses (poussières de freins).
    Il ne restera plus qu'à bien rincer et à essuyer la surface."
    Mode d'emploi / application :
    Pulvériser et attendre qu'il passe de sa couleur claire à une couleur violacée.
    Dilution(s) :
    Aucune
    Temps de pose :
    Il est indiqué 5 minutes sur le flacon
    Senteur :
    Une horreur, c'est indescriptible :berk1:
    Avantages :
    Son ph neutre et donc sans craintes pour tous types de jantes
    Inconvénients :
    L'odeur et son prix
    Produits concurrents :
    Wolf's chemicals - Brake duster
    Disponibilité :
    Shinerama pour ne citer qu'eux
    Ordre de prix :
    12.95£ les 500ml
    19.95£ le Litre
    52£ le gallon
    Conclusion :
    Trés bon produit qui va retirer les contaminants des vos jantes.
    Vous l'aurez compris ce n'est pas un nettoyant jantes, quand vous allez l'utiliser, il vous faudra déjà nettoyer vos jantes comme à votre habitude, les sécher et seulement aprés utiliser ce produit, il sert uniquement à décontaminer/enlever les résidus incrustés dans le vernis.
    Partout on peut lire que celui ci est supérieur au brake duster, mouais regardez mon compte rendu en photos.
    oui c'est indéniable, sans lui ou le brake duster, je n'aurais pas pu avoir ce résultat
    Liens vers des exemples :
    http://www.esthauto.com/viewtopic.php?f=11&p=191640#p191640
  2. Com
    By:Compte désactivé18 Février 2012
    [CARPRO] IronX
    À acheter alors ?
    Il a l'air efficace.
    Super Modérateur
    Re: [CARPRO] IronX
    Oui mais je dirais que dans certains cas, il est préférable d'avoir un pinceau type autoglym.
  4. Com
    By:Compte désactivé19 Février 2012
    [CARPRO] IronX
    Tu pulvérise et tu le passe partout avec le pinceau ? Et tu le laisse ensuite agir ? Puis tu rinces au bout de combien de minutes ?
    By:Béhième19 Février 2012
    Super Modérateur
    Re: [CARPRO] IronX
    Je nettoie mes jantes, donc comme dab produits + pinceaux etc
    Je fais les 4 jantes et quand je reviens sur la 1ère elle est plus ou moins sèche, oh pire je passe un coup de mf.
    En principe je passe du dégoudronnant et j'en retire pas mal, hier j'ai halluciné aucun point de goudrons :aille:
    J'applique le ironX, je laisse agir au moins 5 minutes.
    En cas de forte contamination comme hier, j'avais mis le pinceau ag dans de l'eau tiède et ainsi je l'ai passé sur les jantes.
    Puis j'ai rincé.
    Derrière ça, je relave avec un gant + shampoo.
    A savoir que le pinceau n'est pas obligatoire, en cas extrême comme hier c'est un gros plus.
  6. Com
    Re: [CARPRO] IronX
    Donc tu passes le IRONX avec le pinceau puis tu laisses agir 5 minutes ?
    Super Modérateur
    Re: [CARPRO] IronX
    Non, j'applique le ironx, je laisse agir 5 minutes et seulement aprés les 5 minutes dans certains cas j'utilise un pinceau.
    Un pinceau n'est pas utile quand les jantes sont entretenues régulièrement.
  8. tchio lulu
    By:tchio lulu20 Février 2012
    Re: [CARPRO] IronX
    merci pour la fiche.
    J'ai ici la reponse concermant le pulvé :hehe:
    un pinceau stylevp , car il a l'air un peu rigide ?
    By:Béhième20 Février 2012
    Super Modérateur
    Re: [CARPRO] IronX
    de quel pinceau vp tu parles car tu en à 2 différents ?
  10. tchio lulu
    Re: [CARPRO] IronX
    il y en a avec des poils arrondis
  11. Com
    By:Compte désactivé20 Février 2012
    Re: [CARPRO] IronX
    Je viens de tester l'IronX que j'avais en petit sample.
    Une tuerie. Les résidus de plus de 50.000 km sont partis sans effort.
    Je compte donc acheter ce produit en grand contenant, sinon le Wolf Chemical est identique si je dois en acheter un ? Lequel prendre ? Merci.
  12. Connect
    By:Connect20 Février 2012
    4 Novembre 2008
    Re: [CARPRO] IronX
    Tu n'as pas fait de photos ? :mrgreen:
  13. Com
    [CARPRO] IronX
    Si ;)
    Super Modérateur
    Re: [CARPRO] IronX
    Le brake duster fera aussi bien, sauf qu'il est plus épais et demandera donc plus de temps pour agir.
  15. Com
    Re: [CARPRO] IronX
    Beaucoup plus ? Mais tout aussi efficace ?
    Super Modérateur
    Re: [CARPRO] IronX
    Tout aussi efficace oui, mais plus long.
  17. Com
    Re: [CARPRO] IronX
    À part shinearama où trouver du wolf chemical ou ironX ?
    By:Béhième21 Février 2012
    Super Modérateur
    Re: [CARPRO] IronX
    Elite car care, lacuradellauto et surement d'autres.
  19. Vac
    By:Vac7218 Mars 2012
    13 Mars 2012
    E2220cdiw210 MeganeII Gsxr
    Re: [CARPRO] IronX
    Celui ci je le met dans ma liste de course pour mes jantes , je viens de commancer une rénov sur la classe e et les jantes n'ont jamais été faites depuis 8 ans au moins , j'ai fait des photos :pleur4: :pleur4: :berk1:
  20. Nosman
    By:Nosman18 Mars 2012
    23 Avril 2011
    Matthieu
    Re: [CARPRO] IronX
    acheté depuis peu, reste plus qu'a tester :diable:
