Airchamber / CarCoon
Discussion dans 'Le garage' créé par Compte désactivé, 8 Octobre 2012.
  1. Com
    By:Compte désactivé8 Octobre 2012
    Non-contact, Non-Deflating, Hi Tech Protection For Your Vehicle.
    Airchamber is a unique, lightweight construction designed to protect your cherished vehicle from the damaging effects of damp and dust. The hi-tech static trap filtration system removes all abrasive particulates from the atmosphere, whilst the twin fans keep air circulating to prevent moisture from settling on the paintwork.
    Features & Benefits:
    Rapid assembly lightweight internal frame
    Full height door panels allow easy access from both sides
    Does not collapse when not in use - drive in, zip up, switch on!
    UV protective, flame resistant material tested to temperatures as low as -25 deg C
    Controls rapid changes in air temperature - preventing condensation, damp & rust
    Durable base sheet - fuel, oil & brake fluid repellent
    Supplied with 2 x 12V brushless electric fan motors
    Highly economical - typical running costs around £25 pa
    Airchamber Sizes: (Length x Width x Height)
    In deciding the correct size for your car the following factors should also be considered:-
    The amount of available space
    Does the garage door intrude into the available space (i.e. up and over doors)
    How much space is required around the vehicle inside the Airchamber
    Are you likely to be replacing the vehicle at some point for a bigger one!
    Airchamber (S) - 4.5 x 2.0 x 1.8m
    Airchamber (M) - 5.2 x 2.0 x 1.8m
    Airchamber (XM SPECIAL) - 5.0 x 2.2 x 1.8m
    Airchamber (XM) - 5.2 x 2.2 x 1.8m
    Airchamber (L) - 5.7 x 2.0 x 1.8m
    Airchamber (XL) - 5.7 x 2.2 x 1.8m
    Airchamber (XXL) - 6.7 x 2.2 x 1.8m
    [youtube]y7mAPbmmICU[/youtube]
    Et dans le même esprit : CarCoon :
    [youtube]b01VfCU0ABE[/youtube]
    Un truc de malade !!!!
  2. jamalasa
    By:jamalasa9 Octobre 2012
    Moi je propose qu'on fasse une commande groupée, qu'on achète un hangar, et qu'on prenne une équipe surveillance avec kalach pour nous garder nos cars... :happy1:
  3. tchio lulu
    By:tchio lulu9 Octobre 2012
    j avais deja vu ces housses. Moi je pense que pour quelqu un qui stocke son auto c est un bon produit. maintenant, je me vois mal sortir la voiture de la housse a 3 h du mat pour aller bosser
  4. Com
    By:Compte désactivé9 Octobre 2012
    Excellent quand tu as une classic :D
